21615 Discussions
Using Virtual JTAG interface as additional input
Helo there,
let say i have block design with input X , and output Y.
To save IO, i'm planning to use the Virtual JTAG.
my intend is that,
when assign Y = load_mdio? tdo_sig: tdi_sig; //bypass
assign X = load_mdio? tdi_sig :1'bz; //tristate
load_mdio = ir_in_sig[1] && ~ir_in_sig[0];
Q)
1) Will this work?
2) with this setup, I'm assuming that all I have to do is set ir_in_sig=2'b10 , and my internal X,Y should be working like any other pins at TDI/TDO?
3) I don't havethe hardware to test this yet , after I program the ir_in_sig via JTAG cable (Quartus_stp), can i disconnect the cable and use TDI/TDI for other purpose as i wanted?
thanks for your help.
rgds,
cellv
