Programmable Devices
Using schematic
Hi all, I've just tried for the very first time to use a CPLD and am having problems with transfering a schematic to the CPLD.
Can anyone explain why my schematic has errors on the pinouts
Warning (20028): Parallel compilation is not licensed and has been disabled
Warning (10034): Output port "D0" at test.v(36) has no driver
Warning (10034): Output port "D1" at test.v(37) has no driver
Warning (10034): Output port "D2" at test.v(38) has no driver
Warning (10034): Output port "D3" at test.v(39) has no driver
Warning (13024): Output pins are stuck at VCC or GND
Warning (13410): Pin "D0" is stuck at GND
Warning (13410): Pin "D1" is stuck at GND
Warning (13410): Pin "D2" is stuck at GND
Warning (13410): Pin "D3" is stuck at GND
Warning (21074): Design contains 5 input pin(s) that do not drive logic
Warning (15610): No output dependent on input pin "CLK"
Warning (15610): No output dependent on input pin "CLR"
Warning (15610): No output dependent on input pin "DATA"
Warning (15610): No output dependent on input pin "LATCH"
Warning (15610): No output dependent on input pin "SEL"
Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature.
Warning (169140): Reserve pin assignment ignored because of existing pin with name "CLK"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "CLR"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "D0"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "D1"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "D2"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "D3"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "DATA"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "LATCH"
Warning (169140): Reserve pin assignment ignored because of existing pin with name "SEL"
