21602 Discussions
Using sdram_control_4Port module in VHDL
All,
I am new to VHDL. I am trying to use the sdram_control_4Port form the terasic to read and write to SDRAM. The end goal is to use the TRDB_D5M camera to capture and image then modify the data in the SDRAM and display the image on the screen.
The hardware platform is DE2-70 board
Bellow is my code. Any help is appreciated.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY final_project IS
PORT (
--////////////////// Clock Input ////////////////////
iCLK_28 : IN STD_LOGIC; -- 28.63636 MHz
iCLK_50 : IN STD_LOGIC; -- 50 MHz
iCLK_50_2 : IN STD_LOGIC; -- 50 MHz
iCLK_50_3 : IN STD_LOGIC; -- 50 MHz
iCLK_50_4 : IN STD_LOGIC; -- 50 MHz
iEXT_CLOCK : IN STD_LOGIC; -- External Clock
--////////////////// Push Button ////////////////////
iKEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0); -- Pushbutton[3:0]
--////////////////// DPDT Switch ////////////////////
iSW : IN STD_LOGIC_VECTOR(17 DOWNTO 0); -- Toggle Switch[17:0]
--///////////////////// SDRAM Interface ////////////////
DRAM_DQ : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0); -- SDRAM Data bus 32 Bits
oDRAM0_A : OUT STD_LOGIC_VECTOR (12 DOWNTO 0); -- SDRAM0 Address bus 13 Bits
oDRAM1_A : OUT STD_LOGIC_VECTOR (12 DOWNTO 0); -- SDRAM1 Address bus 13 Bits
oDRAM0_LDQM0: OUT STD_LOGIC; -- SDRAM0 Low-byte Data Mask
oDRAM1_LDQM0: OUT STD_LOGIC; -- SDRAM1 Low-byte Data Mask
oDRAM0_UDQM1: OUT STD_LOGIC; -- SDRAM0 High-byte Data Mask
oDRAM1_UDQM1: OUT STD_LOGIC; -- SDRAM1 High-byte Data Mask
oDRAM0_WE_N : OUT STD_LOGIC; -- SDRAM0 Write Enable
oDRAM1_WE_N : OUT STD_LOGIC; -- SDRAM1 Write Enable
oDRAM0_CAS_N: OUT STD_LOGIC; -- SDRAM0 Column Address Strobe
oDRAM1_CAS_N: OUT STD_LOGIC; -- SDRAM1 Column Address Strobe
oDRAM0_RAS_N: OUT STD_LOGIC; -- SDRAM0 Row Address Strobe
oDRAM1_RAS_N: OUT STD_LOGIC; -- SDRAM1 Row Address Strobe
oDRAM0_CS_N : OUT STD_LOGIC; -- SDRAM0 Chip Select
oDRAM1_CS_N : OUT STD_LOGIC; -- SDRAM1 Chip Select
oDRAM0_BA : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); -- SDRAM0 Bank Address
oDRAM1_BA : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); -- SDRAM1 Bank Address
oDRAM0_CLK : OUT STD_LOGIC; -- SDRAM0 Clock
oDRAM1_CLK : OUT STD_LOGIC; -- SDRAM1 Clock
oDRAM0_CKE : OUT STD_LOGIC; -- SDRAM0 Clock Enable
oDRAM1_CKE : OUT STD_LOGIC; -- SDRAM1 Clock Enable
--/////////////////////// LED ////////////////////////
oLEDG : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); -- LED Green[8:0]
oLEDR : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) -- LED Red[15:0]
END final_project;
ARCHITECTURE circuit OF final_project IS
SIGNAL sdram_ctrl_clk: STD_LOGIC ;
SIGNAL WR1_FULL,WR2_FULL,RD1_EMPTY,RD2_EMPTY: STD_LOGIC ;
SIGNAL WR1_USE,WR2_USE,RD1_USE,RD2_USE: STD_LOGIC_VECTOR (8 DOWNTO 0) ;
SIGNAL RD2 : STD_LOGIC_VECTOR (15 DOWNTO 0);
SIGNAL DRAM0_CS_N,DRAM1_CS_N,DRAM0_DQM,DRAM1_DQM : STD_LOGIC_VECTOR (1 DOWNTO 0) := b"00" ;
SIGNAL DRAM0_A,DRAM1_A : STD_LOGIC_VECTOR(11 DOWNTO 0);
SIGNAL RD2_temp : STD_LOGIC_VECTOR (15 DOWNTO 0);
COMPONENT sdram_pll IS
PORT (
inclk0 : IN STD_LOGIC;
c0 : OUT STD_LOGIC;
c1 : OUT STD_LOGIC;
c2 : OUT STD_LOGIC
END COMPONENT;
COMPONENT Sdram_Control_4Port IS
PORT (
--HOST Side
REF_CLK : IN STD_LOGIC; --System Clock
RESET_N : IN STD_LOGIC; --System Reset
-- FIFO Write Side 1
WR1_DATA : IN STD_LOGIC_VECTOR (15 DOWNTO 0); --Data input
WR1 : IN STD_LOGIC; --Write Request
WR1_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write start address
WR1_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write max address
WR1_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Write length
WR1_LOAD : IN STD_LOGIC; --Write register load & fifo clear
WR1_CLK : IN STD_LOGIC; --Write fifo clock
WR1_FULL : OUT STD_LOGIC; --Write fifo full
WR1_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Write fifo usedw
-- FIFO Write Side 2
WR2_DATA : IN STD_LOGIC_VECTOR (15 DOWNTO 0); --Data input
WR2 : IN STD_LOGIC; --Write Request
WR2_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write start address
WR2_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write max address
WR2_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Write length
WR2_LOAD : IN STD_LOGIC; --Write register load & fifo clear
WR2_CLK : IN STD_LOGIC; --Write fifo clock
WR2_FULL : OUT STD_LOGIC; --Write fifo clock
WR2_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Write fifo usedw
-- FIFO Read Side 1
RD1_DATA : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); --Data output
RD1 : IN STD_LOGIC; --Read Request
RD1_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read start address
RD1_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read max address
RD1_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Read length
RD1_LOAD : IN STD_LOGIC; --Read register load & fifo clear
RD1_CLK : IN STD_LOGIC; --Read fifo clock
RD1_EMPTY : OUT STD_LOGIC; --Read fifo empty
RD1_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Read fifo usedw
-- FIFO Read Side 2
RD2_DATA : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); --Data output
RD2 : IN STD_LOGIC; --Read Request
RD2_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read start address
RD2_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read max address
RD2_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Read max address
RD2_LOAD : IN STD_LOGIC; --Read register load & fifo clear
RD2_CLK : IN STD_LOGIC; --Read fifo clock
RD2_EMPTY : OUT STD_LOGIC; --Read fifo empty
RD2_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Read fifo usedw
-- SDRAM Side
SA : OUT STD_LOGIC_VECTOR (11 DOWNTO 0); --SDRAM address output
BA : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); --SDRAM bank address
CS_N : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); --SDRAM Chip Selects
CKE : OUT STD_LOGIC; --SDRAM clock enable
RAS_N : OUT STD_LOGIC; --SDRAM Row address Strobe
CAS_N : OUT STD_LOGIC; --SDRAM Column address Strobe
WE_N : OUT STD_LOGIC; --SDRAM write enable
DQ : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0);--SDRAM data bus
DQM : OUT STD_LOGIC_VECTOR (1 DOWNTO 0) --SDRAM data mask lines
END COMPONENT;
BEGIN
u1 : sdram_pll PORT MAP (iCLK_50,sdram_ctrl_clk,oDRAM0_CLK,oDRAM1_CLK);
u2 : Sdram_Control_4Port PORT MAP (iCLK_50,'1',sdram_ctrl_clk,b"0001000100010001",'1',b"00000000000000000000000",b"00101000000000000000000",b"100000000",'1',iCLK_28,WR1_FULL,WR1_USE,
b"0000000000000000",'-',b"00000000000000000000000",b"00000000000000000000000",b"000000000",'0','Z',WR2_FULL,WR2_USE,
oLEDR,'1',b"00000000000000000000000",b"00101000000000000000000",b"100000000",'1',iCLK_28,RD1_EMPTY,RD1_USE,
RD2_temp,'-',b"00000000000000000000000",b"00101000000000000000000",b"100000000",'0','Z',RD2_EMPTY,RD2_USE,
DRAM0_A,oDRAM0_BA,DRAM0_CS_N,oDRAM0_CKE,oDRAM0_RAS_N,oDRAM0_CAS_N,oDRAM0_WE_N,DRAM_DQ,DRAM0_DQM);
oDRAM0_A <= "0"&DRAM0_A;
oDRAM0_CS_N <= '0' WHEN (DRAM0_CS_N = "00") ELSE '1';
oDRAM0_LDQM0<=DRAM0_DQM(0);
oDRAM0_UDQM1<=DRAM0_DQM(1);
oLEDG(0)<=sdram_ctrl_clk;
END ARCHITECTURE;
