21605 Discussions
Using the global clock network in MAXII device
I have a clock signal that I need distributed to my components in a design. This is my first time using a MAXII, so I'm not very sure of myself here - I've made a simple clock signal that takes the on-board developer and divides by two, but I'm aware that clock delay may become a problem if I don't distribute the signal appropriately.
My clock divider code (currently)
LIBRARY ieee; USE ieee.std_logic_1164.ALL; entity CLOCK_DIVIDER is port( reset : in std_logic; clk : in std_logic; half_clk : out std_logic ); end CLOCK_DIVIDER; architecture CLOCK_DIVIDER of CLOCK_DIVIDER is signal tick : std_logic; begin process(clk, reset) begin if reset = '1' then tick <= '0'; elsif clk = '1' and clk'EVENT then if tick = '0' then tick <= '1'; elsif tick = '1' then tick <= '0'; end if; end if; end process; process(tick) begin half_clk <= tick; end process end CLOCK_DIVIDER;
clk comes from a pin with a signal from an external oscillator (PIN_H5). half_clk is routed to all my components but I'm not sure if it's using one of the four global clock networks that my data sheet tells me I have available - how do I make sure it uses a global net?
sorry but i don't have a answer of your problem but i have a question. how you interface your MaxII with the memory which is store the configuration of FPGA ??
thanks for your help.
I use a USB Blaster cable.
--- Quote Start ---
--- Quote End ---
You can expect, that Quartus will assign global clock resources automatically, if appropriate. You usually don't care for this low level details. The delay between clk and half_clk will exist anyway, and possibly cause problems for signals crossing between both clock domains. Quartus timing analyzer will you inform about it, however.
The regular suggestion is to avoid clock dividers for internal clock signals and use divided clock enable signals instead.
--- Quote Start ---
--- Quote End ---
Other than most FPGA, MAXII has internal non-volatile configuration memory.
