21595 Discussions
VHDL Chronometer NEXYS 2 Memorizing Problem
To make this as short as possible, I have a project at school that requires me to program a Chronometer on the nexys 2 board. The Chronometer must start, pause,reset and record the times that are on the 7 segment display when you press the pause button,and show them all in order when i press a different button from the three mentioned before. I have made it start,pause and reset but i have no clue how to make it memorize the time and then display it.
This is my code:
-- Verified 9/3/08 by jht
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity stopwatch is
Port ( clk : in std_logic;
btns : in std_logic_vector(3 downto 1);
leds : out std_logic_vector(7 downto 5);
an : out std_logic_vector(3 downto 0);
seg : out std_logic_vector(6 downto 0);
dp : out std_logic
end stopwatch;
architecture Behavioral of stopwatch is
signal Dhex : std_logic_vector(15 downto 0);
signal Start, Stop, Reset: std_logic := '0';
signal TP_001s: std_logic := '0';
signal run_pulse: std_logic := '0';
signal Blink_on: boolean := FALSE;
signal EN: std_logic_vector(3 downto 0) := "1111";
begin
-- Use seven segment display to show elapsed time.
U_SSD: entity HEXSSD port map (hex => Dhex, DP => "0100" , CLK => CLK,
DISP_SEG(7) => dp, DISP_SEG(6 downto 0) => seg , Disp_AN => an,
EN => EN);
-- Generate 0.01 sec tick.
U10MS: entity NCNT generic map(500_000) port map (CLK, TP_001s);
-- Use DEC_UP_CNT to measure elapsed time.
UDUC: entity DEC_UP_CNT(arch) port map(CLK => CLK, RST => Reset,
EN => Run_Pulse, COUNT => Dhex);
Run_pulse <= TP_001s and START;
-- Remember which button was pressed.
process(clk)
begin
if clk'event and clk = '0' then
if (Reset = '1') and (Start ='1') then
Reset <= '0';
end if;
case btns is
when "100" =>
Start <= '1';
Stop <= '0';
Reset <= '0';
when "010" =>
Start <= '0';
Stop <= '1';
Reset <= '0';
when "001" =>
Reset <= '1';
Stop <= '0';
when others =>
NULL;
end case;
end if;
end process;
leds(7) <= Start;
leds(6) <= Stop;
leds(5) <= Reset;
-- Blink seven segment display
-- Add blink when 99.99.
Blink_on <= TRUE when Dhex = X"9999" else FALSE;
process (clk)
variable count: integer range 0 to 25 - 1;
begin
if TP_001s = '1' then
count := count + 1 mod 25;
if count = 0 then
if Blink_on then
EN <= not EN;
else
EN <= "1111";
end if;
end if;
end if;
end if;
end process;
end Behavioral;
Could anyone help? Thanks a lot :)
