21600 Discussions
[VHDL] Problem with signal type "std_logic_vector(0 downto 0)"
I use IP module, where data bus width is set to '1'.
In VHDL code it is declared as type "std_logic_vector(0 downto 0)", but for compiler this is not the same as "std_logic", type of signal assigned to this bus.
I changed manually in the component's source code type "std_logic_vector" to "std_logic", but then Model-Sim started to cry, that somewhere in its library in the component's entity is type "std_logic_vector".
Does anyone have an idea, how to fix it? Maybe there is a compiler option to ignore it?
greetings
No you need to change the signal type to std_logic everywhere. Maybe you forgot to do the change in one place?
You can keep it as std_logic_vector and access your variable using parenthesis : data(0), no ?
--- Quote Start ---
--- Quote End ---
It's working. I tried data(0 downto 0) and it failed, but data(0) is ok.
Thanks!
--- Quote Start ---
Thanks!
--- Quote End ---
That is because data(0 downto 0) returns a std_logic_vector of length 1. data(0) returns a std_logic
VHDL is strongly typed so it wont let you connect incorrect types without converting them properly.
