i'm currently working on cyclone III (ep3c120f780c7n) development board and try to do something without any idea on how to realize it i made working the following project "cycloneIII_3c120_dev_niosII_standard" with the simple_socket_server and the web_server now i would like to reuse this design but for a more specific application, I have a camera (mt9m011) which is working after an I2C configuration and send me some pixels datas what I want to know is : (how) can I put my vhdl code in that design to keep pixels in the ddr2 and then send this datas to the PC any ideas is welcome because I am working on this since weeks without result and I don't understand verilog code as the top level code thanks in advanceLink Copied
1> Regarding loading the Camera Pixel Data to DDR: You can add a custom module, It has to do the following a) takes input from the camera sensor, b)write it into a fifo wrt to camera_clk and then read from the fifo wrt[with respect to] ddr_clk c) Then write it to the ddr by designing a simple avalon bus interface that supports the DMA component already available in the SOPC builder in VHDL/verilog DMA component is instanced to your design in the SOPC along with the custom component [above explained] you designed. Regards, Jagadeesh.B
