VHDL code_1
Hello guys
I have one more problem with the altera Vhdl code using max_plus_II
I wirte this simple code :
ibrary ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity PWM_n4 is
port
clk48Mhz : in std_logic;
encoder : in std_logic_vector(13 downto 1);
cntr_in : in std_logic_vector(12 downto 0);
out_signal : out std_logic
end;
architecture arc_PWM_n4 of PWM_n4 is
signal signal_out : std_logic := '0';
signal cntr : integer range 0 to 4861 := 0;
signal reset_cntr : std_logic := '0';
signal n_encoder : std_logic_vector(13 downto 1) := encoder;
signal reset_encoder : std_logic := '1';
begin
process
begin
if rising_edge(clk48Mhz) then
if reset_cntr = '1' then
cntr <= 0;
else
cntr <= cntr + 1;
end if;
if reset_encoder = '1' then
n_encoder <= encoder;
end if;
end if;
end process;
process(clk48Mhz)
begin
if falling_edge(clk48Mhz) then
reset_cntr <= '0';
reset_encoder <= '0';
if cntr = cntr_in then
if signal_out = '1' then
signal_out <= '0';
else
signal_out <= '1';
end if;
else if cntr = 4860 then
signal_out <= '1';
else if cntr = 4861 then
reset_cntr <= '1';
reset_encoder <= '1';
end if;
end if;
end if;
end if;
end process;
out_signal <= signal_out;
end;
when I simulate this code I got the results I need, but when I connect this code to a output pin and the pin to a scope, the scope shows me the opposite of what the simulator shows.
what should I do, why it is behave like that? it should be the same not the opposite.
thx a lot
scope not scoop :(
Hi
Which one is correct?? I mean the simulated stuff or the actual signal on the pin.
check up your simalution and synthesis settings....
my guess is in either of this you are enabling inverted output generation..
try adding a reset signal
I would try adding asynchronous reset signal. It would look something like this:
begin
process
begin
if asynchronous_reset = '1' then
--here you can put init values to signals, for example:
out_signal <= (others => '0');
elsif rising_edge(clk48Mhz) then
cntr <= 0;
else
cntr <= cntr + 1;
end if;
end if;
end if;
end process;
I assume that your output is logically inverted. You can also add simple output inverter. It will solve your problem easily :)
