VHDL comparison
Hi all,
I'd like to write a limiter:
1. Input/output are 16 bit signed number
2. If input is -32768 then output is limited by -32767, otherwise the output is just bypass of the input.
I wrote a code as follow:
library ieee;
use ieee.std_logic_1164.all;
entity numLimiter16 is
port(
clk: in std_logic;
data_in: in std_logic_vector(15 downto 0);
data_out: out std_logic_vector(15 downto 0)
end numLimiter16;
architecture rtl of numLimiter16 is
signal tmp : std_logic_vector(15 downto 0);
begin
process
begin
if (clk'event and clk='1') then
data_out <= "1000_0000_0000_0001" when (tmp = "1000_0000_0000_0000") else tmp;
end if;
end process;
tmp <= data_in;
end rtl;
When I compile the code I met the error message:
Error (10500): VHDL syntax error at numLimiter16.vhd(21) near text "when"; expecting ";"
Could you point out which one do I have to correct?
Thanks!
Try this:
process(clk) begin if rising_edge(clk) then if (data_in = X"8000") then data_out <= X"8001"; else data_out <= data_in; end if; end if; end process; Cheers,
Dave
Thanks Dave, works great!
