21613 Discussions
VHDL multiplication operator
Hi all,
I am new to coding in VHDL and using FPGAs. I keep getting this error when I go to complie my code. Error (10327): VHDL error : can't determine definiton of operator "*"--found 0 possible defintions. The error is on this line in my architecture:
Synchro_36(13 DOWNTO 0) <= Gear_calc(13 DOWNTO 0) * "00100100";
I am trying to multiply a standard logic vector and a constant but with different data types. I added these libraries to rule out the possible data type issue:
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_arith.ALL;
USE IEEE.std_logic_unsigned.ALL;
Is there something simple I am missing here?
Thanks for the help!
you need to multiply by signed (or unsigned). You can just add a cast to std_logic i.e.
result <= std_logic_vector(signed(input)*constant);
