VHDL question
Hi all!
According to std.standard:
TYPE string IS ARRAY ( positive RANGE <> OF character);
"hello" is a valid string litteral
"" is a valid string litteral too, it is the empty string.
Let
TYPE foo IS ARRAY ( positive RANGE <> OF integer);
(0, 1, 1, 2, 3, 5) is a valid foo litteral
What is the litteral for an empty foo?
Thx
Julien
Did you try () or (null)?
The only way I know is to create a null array constant, and use that in place of a literal:
constant NULL_FOO : foo(1 downto 2) := (others => 0);
yes.
neither of these work :(
OK for 1 downto 2 range.
Any other (cleaner) way?
I dont think there is. Could you explain why you want to do it?
another less "clean" way - declare a pointer to foo.
type foo_ptr_t is access foo;
variable foo_ptr : foo_ptr_t;
and then you can actually compare it to null:
if foo_ptr = null then
...etc
But that is getting rather extreme.
