Hi folks, I`m new.
I have CycloneIII Starter Board (cp3c25f324c6) with LCD multimedia kit. I'm trying initialising audio chip via i2c. Before programing, there is Vcc from external pull up resistors on sda and scl pins. After programing, sda is on E1 pin and works - i see data signal on osciloscope, but scl on F3 pin (special VREFB1N0 used as I/O) is after programing pulldown to gnd. Both pins are in same bank, bidir... Have you any idea whats wrong? Something with VREF config?Link Copied
