21592 Discussions
Verify problem while runing on Nios II hardware
Hi there,
when i try to run my project on the Nios II hardware i get the following problem:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00070000: verified
Initializing CPU cache (if present)
OK
Downloading 00080000 ( 0%)
Downloaded 43KB in 0.7s (61.4KB/s)
Verifying 00080000 ( 0%)
Verify failed between address 0x80000 and 0x8ABDF
Leaving target processor paused
I use the SRAM memory on DE1 board which has the Cyclone II FPGA. I also checked the base and end address for SRAM, and there is also no overlaping. The SRAM memory has the base address 00080000 and 0008ffff end address. I also use the on-chip memory for better perfomance.
Have anyone an idea how to fix that problem?
Best regards!
Check your timings, both in SOPC builder for the SRAM and in Timequest when you compile the Quartus project.
You can also compile a memory test example, run it from the on-chip memory and have it test the SRAM.
check in pin planner, positions of
1 reset
2 clock
check in system library properties that you are using on chip memory as program memory
