21602 Discussions
Generating Dual Port RAM in Megawizard using Command Line
I'm trying to generate dual port ram in megawizard using command line. I would like to use dual clock with seperate "input" & "output" clocks.
I use the command "qmegawiz -silent module=altsyncram -f: dualportram_params.txt mydualportram.v".
address_aclr_b=NONE
address_reg_b=CLOCK0
clock_enable_input_a=BYPASS
clock_enable_input_b=BYPASS
clock_enable_output_b=BYPASS
intended_device_family="Stratix"
lpm_type=altsyncram
numwords_a=32
numwords_b=32
operation_mode=DUAL_PORT
outdata_aclr_b=NONE
outdata_reg_b=CLOCK1
power_up_uninitialized=FALSE
read_during_write_mode_mixed_ports=DONT_CARE
widthad_a=5
widthad_b=5
width_a=8
width_b=8
width_byteena_a=1
clock1=used
I get this error message.
Error: The specified megafunction or wizard is not supported in command line mode.
Parameter OUTDATA_REG_B has been assigned the value CLOCK1 which is incompatible with the current settings of ADDRESS_REG_B<CLOCK0>. The legal value is CLOCK0:UNREGISTED.
I suspect my parameter lists got problem. But i don't know how to correct it?
Can anyone help to correct it ??? I need to to generate dualport ram with 2 seperate input & output clocks.
Appreciate anyone's help.
Thanks...
