21588 Discussions
Verilog Generic Input ports
Hi All,
I have an input port to a module which is 5 bits say Inp_A[4:0]. Now the number of such inputs depends on a generic parameter say Gen_Nm.
How can i declare such an input ports in my module.
I have tried
Input [4:0][Gen_Num-1 : 0] Inp_A; &
Input [Gen_Num-1 : 0][4:0] Inp_A; &
Input [Gen_Num-1 : 0] Inp_A[4:0]; &
Input [4:0] Inp_A[Gen_Num-1 : 0];
All these seems to be giving compile error.
Please help me, how to go about this
regards,
freak
your last example is the correct one.
check that parameter is declared within the same file like :
module dummy_mod( Inp_A );
parameter Gen_Num = 3
input [4:0] Inp_A [Gen_Num-1:0]; // should give Gen_Num x 5 bit input
endmodule
but i have seen that quartus sometimes seems to have problems with parameters
if i use them then i do the following
parameter ReloadValue = 47;
wire [5:0] wReloadValue;
assign wReloadValue = ReloadValue;
somewhere this can be used as
rTestReg <= rMyValue + wReloadValue ;
assigning a wire with the parameter works, using the parameter directly doesn't
no idea why
Hi Schmitt,
The example given
is not working.
The compiler is throwing error saying that, this is a System Verilog construct.
Verilog does not support Memory type port declaration.
What is your thoughts on this .
regards,
freak
