I received this error while following a tutorial in a Verilog book:
Error (10170): Verilog HDL syntax error at resistor.v(3) near text ""disciplines.vams"; expecting ".", or an identifier, or "*", or "/" Can anyone provide suggestions on how to fix this? Thanks.Link Copied
Are you trying to compile Verilog-AMS in Quartus II or ModelSim?
Does analog/mixed signal not work in Quartus II? I am using a text that refers to Verilog-AMS.
Also, another error pops up for the other modules I wrote: Error (10170): Verilog HDL syntax error at capacitance.v(3) near text ""disciplines.vams"; expecting "<" Thanks for the help.- Mark as New
--- Quote Start --- Does analog/mixed signal not work in Quartus II? --- Quote End --- No...How would it? -- slacker
Quartus II and ModelSim does not support Verilog-AMS. You need to ADMS compiler like QuestaADMS from Mentor.
