21608 Discussions
Verilog process not implemented correctly in Quartus
It seems as though the following synchronous process in Verilog is sometimes not implemented correctly by Quartus. Why?
always @(posedge clk, negedge rst_n)
if (!rst_n)
begin
hdr_frame_length_s[15:0] <= 1;
end
else if (!srst_n || sof)
begin
end
else if (valid_in)
begin
hdr_frame_length_s <= hdr_frame_length_s + 1;
end
The code above worked as intended in at least one compilation. However in at least one other compilation, sof would not reset the register.
There are two non-standard things here, first the register is reset to 1 not 0, and second the synchronous reset is a logical OR of two inputs.
Why is this code problematic to Quartus?
Thanks for you help,
Avshalom.
It could be the priority logic(if else) and the fact that the sequential last statement overwrites that is causing the problem...
What Quartus Version are you using ?
if 1 compilation is working and 1 not, what about the others ?
one thing that i am not shure is, shouldn't you write
always @(posedge clk or negedge rst_n)
Did you specify the initial values for hdr_frame_length_s ?
like
reg [15:0] hdr_frame_length_s = 16'd1;
or during
initial
begin
end // of initialiser block
Do you get any warnings during compilation ?
Have a look at this Doc Recomended HDL coding guidelines.
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=hdl design guide (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=4&wt.oss_r=1&wt.oss=hdl design guide)
@ kaz
what do you mean with "sequential last statement overwrites" ???
still i am missing the last
else
hdr_frame_length_s <= hdr_frame_length_s;
Okay that one is not realy needed, but an if has an else .. just to be sure
--- Quote Start ---
if (!rst_n)
begin
end
begin
end
else if (valid_in)
begin
end
Avshalom.
--- Quote End ---
how the signals !srst_n and sof generated ? Outside the FPGA ?
Kind regards
GPK
Thanks for all your replies, I appreciate it.
--- Quote Start ---
--- Quote End ---
9.1 sp1 build 304
--- Quote Start ---
--- Quote End ---
I have changed the coding to be more compliant with the recomended HDL coding guidelines, and it seems work properly for this compilation (then again it could be just a "lucky" compilation and the next one will fail again, as happened before).
--- Quote Start ---
--- Quote End ---
SystemVerilog
--- Quote Start ---
like
or during
initial
begin
--- Quote End ---
the code is synthesizable, register is initialized @ negedge rst_n
--- Quote Start ---
--- Quote End ---
Not any that seem related
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
These are synchronous register outputs (synchronous to clk)
