Programmable Devices
21615 Discussions
Verilog to VHDL
Can some one tell my what this code is in VHDL?
always @(posedge vga_clk or negedge reset_n) begin if (reset_n == 0) sync_n <= 0; else if (1) sync_n <= vga_start ? (vsync_temp ~^ hsync_temp) : sync_n_init; end
Some think like this?
process (vga_clk, reset_n) begin if reset_n = '0' then sync_n <= std_logic'('0'); elsif vga_clk'event and vga_clk = '1' then if (std_logic_vector'("00000000000000000000000000000001")) /= std_logic_vector'("00000000000000000000000000000000") then sync_n <= Vector_To_Std_Logic(A_WE_StdLogicVector((std_logic'(vga_start) = '1'), (vsync_temp xnor hsync_temp), (std_logic_vector'("0000000000000000000000000000000") & (A_TOSTDLOGICVECTOR(sync_n_init))))); end if; end if;
Only (vsync_temp xnor hsync_temp) is wrong I think.
The operator ~^ is a XNOR.
0 ~^ 0 is 1
0 ~^ 1 is 0
1 ~^ 0 is 0
1 ~^ 1 is 1
depending on vga_start,
if 1 sync_n is set to the result of the xnor ,
if 0 sync_n is set to the value of sync_n_init;
unfortunately i cannot read VHDL, it's too much to type, thats why i do it with verilog
I believe the following example would be equivalent VHDL for your Verilog. The
VHDL you provided appears to be machine generated.
process (reset_n, vga_clk)
begin
if (reset_n = '0') then
sync_n <= '0';
elsif (vga_clk'EVENT and vga_clk = '1') then
if (vga_start = '1') then
sync_n <= vsync_temp xnor hsync_temp;
else
sync_n <= sync_n_init;
end if;
end if;
end process;
