I am getting this type of warning while synthesizing the design.. any suggestion/advice??? warning (14130): reduced register "buf_reg[13][0]" with stuck data_in port to stuck value vccLink Copied
It means that whatever logic you have on the input to the register named BUF_REG[13][0] always generates a '1' value. Therefore there is no point in adding a register and Quartus deletes it.
You need to check the logic driving that register bit. Hope this helps- Mark as New
Yes It is always tied to High, thanks for your replay
