21594 Discussions
Warning : Inferring latches for signal or varialbe
Hi all,
Am new to VHDL and this forum.
When executing my VHDL code am getting following warning "Inferring latches for signal or variable "datain_mem" which holds its previous value in one or more paths"
"Inferring latches for signal or variable "datain_reg" which holds its previous value in one or more paths"
my code is
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity datapath is
port( reset, clk, start: in std_logic;
mainout: out std_logic_vector( 7 downto 0 )
end datapath;
architecture struct of datapath is
component controller is
port( clock,GO,rst: in std_logic;
wr,memdrive,aludrive,ld_x,ld_y: out std_logic;
funct_in:in std_logic_vector(7 downto 0);
addr: out std_logic_vector(7 downto 0);
funct: out std_logic_vector(2 downto 0)
end component;
component memory is
port ( clock,rst,wr,memdrive : in std_logic;
data_in,address : in std_logic_vector(7 downto 0);
data_out : out std_logic_vector(7 downto 0)
end component;
component alu is
port( reset, clk, l_x,l_y,aludrive: in std_logic;
xm,ym: in std_logic_vector( 7 downto 0 );
func_m: in std_logic_vector( 2 downto 0);
aluout: out std_logic_vector( 7 downto 0 )
end component;
signal address: std_logic_vector( 7 downto 0 );
signal wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s: std_logic;
signal funct_s: std_logic_vector(2 downto 0);
signal mainbus : std_logic_vector( 7 downto 0 );
signal datain_mem ,datain_reg: std_logic_vector( 7 downto 0 );
signal dataout_m,math_out,dataxout,datayout : std_logic_vector( 7 downto 0 );
begin
Control:controller port map(clk,start,reset,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s,mainbus,address,funct_s);
Mem: memory port map( clk,reset,wr_s,memdrive_s,datain_mem,address,dataout_m);
Arithlogic: alu port map( reset,clk,ld_x_s,ld_y_s,aludrive_s,datain_reg,datain_mem,funct_s,math_out);
mainout <= math_out;
process(clk,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s,mainbus,dataout_m,math_out)
begin
if (wr_s = '1') then
datain_mem <= mainbus ;
end if;
if (memdrive_s='1' ) then
if (wr_s = '0') then
mainbus <= dataout_m;
else
mainbus<=(others=>'Z');
end if;
if (ld_x_s='1' or ld_y_s='1') then
datain_reg <= mainbus;
end if;
elsif(aludrive_s = '1') then
mainbus <= math_out;
else
end if;
end process;
end struct;
Can anyone pls help me resolve this issue....
Thanks in advance
Change the asynchronous process to a synchronous one.
process(clk,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y _s,mainbus,dataout_m,math_out)
begin
if rising_edge(clk) then
--- Quote Start ---
begin
--- Quote End ---
and you can remove all signals except clk from the sensitivity list.
Hi all,
Thanks for ur answer. its works.
i got some warning like Tri state node(s) do not directly drive top-level pins
Is this warning matters or not... coz when trying to generate functional simulation netlist, am not getting the wave from file.
Can anyone pls help me to resolve this issue...
Thanks in advance.....:) :) :)
