21584 Discussions
What are the differences between e-tile and f-tile?
xingyunzhidi
I want to migrate a project based on e-tile to a new FPGA, but this FPGA only has f-tile. I want to know what changes I should make.
Wincent_Altera
Is there any strict reason for the migration ? What is the IP/design you are trying to migrated ?
The most significant different between E-tile and F-tile in term of Transceiver Performance will be
  • E-tile
  • F-tile
Direct migration might be quite difficult, If you are using certain IP/Design example, I would suggest regenerate a new design from our IP catalog, then go with that.
Wincent_Altera
xingyunzhidi
Thank you, I will review the manuals for the e-tile and f-tile to further understand.
