21592 Discussions
What is VHDL equivalent for Verilog $readmemb to initilze RAM/ROM?
The $readmemb() is mentioned in "Recommended Coding Styles" page 12-26. It seems that this can be used in simulation AND synthesis.
If one unfortunately uses VHDL rather than Verilog, than how does one initialize the RAM/ROM? The idea is to write code such that it gets inferred as the correct type of memory block AND be initilized usign the required content from a MIF file. In other words, it must synthesize.
Unfortunately, Altera has decided not to support what would be the most obvious replacement - the textio package (Xilinx Supports it).
That means the only ways to support mem init in synthesis are:
1. Use a constant and initialise the ram signal in the code:
signal my_ram_sig : my_ram_type := MEM_INIT_CONSTANT;
2. Use a mem init function:
function mem_init_function return ram_t is variable ret : ram_t; begin for i in ret'range loop ret(i) := --some calculated value! end loop; return ret; end function; signal my_ram_sig : my_ram_type := mem_init_function;
3. Use attributes as an init to the ram (either in code or via project assignments)
type mem_t is array(0 to 255) of unsigned(7 downto 0); signal ram : mem_t; attribute ram_init_file : string; attribute ram_init_file of ram : signal is "my_init_file.mif";
The only issue with 3. is that it wont initialise in simulation.
For simulation of method three, you could write a function to read the mif file to init the contents.
You are implying that I write a package that is automatically generated from a differnet programming language, this package shall contain the memory initialization function with the raw data.
No, that would seem a little overkill. How do you need to initialise the ram? do you already have a .mif file? Could you just generate the data easily with a function? Why do you really need to initialise it at all?
If you use the altsyncram component, you can specify a .mif file to use, and it will work in both simulation and synthesis.
