21611 Discussions
What's the parameter 'pfd_clk_select'?
Today, I built a new QuartusII project. The project include two ALT2GXB block, I don't assign the pins. When I compile this project. Quartus point out a error :
Error: WYSIWYG primitive "channel_quad[0].pll0" has CLK[2] port that must be connected because parameter pfd_clk_select is set to 2
What's the parameter pfd_clk_select? How to solve it?
Thank you!
If the ALT2GXB pll_clk port miss source or has a wrong source, Quartus will show this error.
But I don't know what's the parameter pfd_clk_select mean?
