21611 Discussions
What's up with dualcore system?
I have built a single cpu system with onchip memory, it works well.
However,after adding another cpu and another jtag to the SOPCBuilder, and the total component of it is : cpu*2,jtag*2,onchip RAM.
running a helloworld_small on one cpu,
it appears
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
in the console
but not continue
PS.my quartus edition is 8.1
when running the same project in quartus 7.2 ,it seems work.
A couple of things to watch out for:
1 - Are you connecting to the right CPU. If you are using the software build tools or nios2-studio, you can get yourself into trouble here. You may have to manually specify in the debug profile which jtag node id to use when connecting to the processor.
2 - Are you using a jtag uart? If so which cpu is connected to it?
Jake
--- Quote Start ---
Jake
--- Quote End ---
I use two cpu+ two jtag + onchip memory, and all the settings in the NIOSII IDE are correct. However, the dual core runs properly in quartusII 7.2, but not in QuartusII 8.1.
What's up?
