21618 Discussions
Why can't I compile an LVDS TX SERDES design in an Arria 10AX066 when I change the tx_outclk phase with values other then 0,180,360,...
BVand31
The documentation tells me that I can do this in steps of 45degrees, but if I try this, the synthesizer stops with an error.
I use an external configured pll.
I'm using Quartus Prime v17.1.1 Build 593
BVand31
I get these error messages when I put the phase for example to 90:
Error (129029): Input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree", which is a twentynm_lvds_clock_tree primitive, is not connected to a valid source
Info (129005): Input port LVDSFCLK_IN of the atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree" is not connected
Info (129030): Output port LVDS_CLK of a twentynm_iopll primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LVDSFCLK_TOP_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LVDSFCLK_BOT_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Error (129029): Input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree", which is a twentynm_lvds_clock_tree primitive, is not connected to a valid source
Info (129005): Input port LOADEN_IN of the atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree" is not connected
Info (129030): Output port LOADEN of a twentynm_iopll primitive is a valid source for input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LOADEN_TOP_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LOADEN_BOT_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lane0:0:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Error (129029): Input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree", which is a twentynm_lvds_clock_tree primitive, is not connected to a valid source
Info (129005): Input port LVDSFCLK_IN of the atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree" is not connected
Info (129030): Output port LVDS_CLK of a twentynm_iopll primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LVDSFCLK_TOP_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LVDSFCLK_BOT_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Error (129029): Input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree", which is a twentynm_lvds_clock_tree primitive, is not connected to a valid source
Info (129005): Input port LOADEN_IN of the atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree" is not connected
Info (129030): Output port LOADEN of a twentynm_iopll primitive is a valid source for input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LOADEN_TOP_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LOADEN_BOT_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:1:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Error (129029): Input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree", which is a twentynm_lvds_clock_tree primitive, is not connected to a valid source
Info (129005): Input port LVDSFCLK_IN of the atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree" is not connected
Info (129030): Output port LVDS_CLK of a twentynm_iopll primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LVDSFCLK_TOP_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Info (129030): Output port LVDSFCLK_BOT_OUT of a twentynm_lvds_clock_tree primitive is a valid source for input port LVDSFCLK_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree"
Error (129029): Input port LOADEN_IN on atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree", which is a twentynm_lvds_clock_tree primitive, is not connected to a valid source
Info (129005): Input port LOADEN_IN of the atom "lvds_out:\g_lvds_out:g_lvds_out_lanes123:2:i_lvds_out|lvds_out_altera_lvds_171_xojisai:lvds_0|lvds_out_altera_lvds_core20_171_pxhn52y:core|altera_lvds_core20:arch_inst|phase_shifted_tx_outclock_serdes.outclock_tree" is not connected
I also get these messages on other clocks!
Abe
Valued Contributor II
Can you share the link to which document you're referring to? Hope you've instantiated the LVDS IP as a component in the design and not as the top-level design itself.
BVand31
BVand31
See page 19!
Rahul_S_Intel1
Hi ,
 From the Error Message description the LVDS IP is not connected as per the guidelines. Requesting to check the design.
RS​
BVand31
It does compile correctly when I put the phase to 0 or 180 or 360...
But not for 45, 90, 135....
So I assume that I connected the IP correctly?
Or is there a difference when using these phases?
Bruno.
BVand31
Here is a bit of my VHDL:
i_lvds_ref_clk_pll: lvds_ref_clk_pll
port map (
refclk   => i_lvds_ref_clk,
lvds_clk => lvdsPllFastClk,
loaden => lvdsPllLoadEna,
outclk_4 => lvdsPllPxlClk,
locked   => lvdsPllLock,
rst    => pllReset
-- LVDS interfacing
process(lvdsPxlClk, reset)
begin
if reset = '1' then
lvdsData <= (others=>(others=>'0'));
elsif rising_Edge(lvdsPxlClk) then
if lvdsData(0)(0) = '0' then
lvdsData <= (others=>(others=>'1'));
else
end if;
end if;
end process;
g_lvds_out: for i in 1 to c_lvdsLanes-1 generate
i_lvds_out : lvds_out
port map (
ext_coreclock => lvdsPllPxlClk,
ext_fclk   => lvdsPllFastClk(1),
ext_loaden   => lvdsPllLoadEna(1),
tx_coreclock  => lvdsPxlCLk,
tx_in     => lvdsData(i),
tx_out     => o_lvds_data(((i+1)*11)-1 downto i*11),
tx_outclock  => o_lvds_clk(i),
pll_areset => lvdsOutReset
end generate;
Rahul_S_Intel1
Hi ,
With my knowledge no, can you test as stand alone the IP project and check.
RS​
Rahul_S_Intel1
Hi ,
 Requesting to check a standalone PLL and check the standalone PLL is working fine.
Rs​
