21602 Discussions
Why do I see termination logic option errors when I turn on design partitions?
Using QII 14.0. My design successfully compiles when I turn of design partitions. But when I turn on design partition I get following error -
Error (169172): Output pin "adc_sense[2]" specifies a Termination logic option setting of Differential, however, only Series termination is allowed for output pins.
This output is defined to be a tri-state in the top-level using verilog as -
assign adc_sense[2] = (adc_sense_en) ? adc_sense_wire[2] : 'bz;
Any ideas on how I can fix or work around this?
BTW, I have following constraint in the QSF -
set_instance_assignment -name OUTPUT_TERMINATION OFF -to adc_sense[2]
Thank you.
Sanjay
Hey Sanjay,
Did you get this issue resolved?
