21615 Discussions
Why do .SOF files sometimes get made instead of .POF? How can I force a .POF?
I am still learning Quartus II 12 and I'm building simple designs, like 4 inputs that get and-ed and or-ed and then output on Cyclone II devices. Most of the time Quartus makes a .pof, but sometimes it doesn't. Why? How can I fix it? It's not a license issue, no warnings or errors, just no .pof.
Have a look at the assembler report. There is a report that lists all the generated files, and a messages report that should tell you why certain files haven't been generated.
All it said was it was configured to make a .sof. So I went through the device configuration and saw "Use configuration device:" was unchecked, so I checked it and poof, a .pof.
Well I'm back again. Once again I have made a project that does not produce a .pof file, only .sof.
I tried my solution from last time and it didn't work.
I then copied, line for line, the .qsf file from a working project. It did not work.
Is there an undocumented setting to turn POF generation on and off? If so, can someone please give me a hint as to where to find it? Thanks.
Update:
Choosing a configuration device like EPCS4 makes the GUI tool produce a .pof.
However, the command line tools still only makes a .sof
And the GUI and CL tool make difference sized .sof files... perhaps they are seeing different config devices?
