21608 Discussions
Why does my code not like the addition clock in to the always loop?
This is my very simple code. If i have a single clock going in to the always loop, i get very few warnings and when i simulate it, i get an output. If i add a second clock in to the always loop, as shown here. I don't get any errors but for some reason it doesn't like it and i don't get anything out. I do quite quite of few extra warnings.
The clocks are generated by a PLL. I have a 50Mhz clock going in to the PLL and output 2 300Mhz outputs that are 180 degrees out of phase of each other. I'm using a Cyclone III EP3C25F324.
module Pulse(input clk, input clk2, output reg out, output reg state_var, //debug outputs output reg counter); parameter init = 4'd0, run = 4'd1; initial begin state_var<=init; //Straight in to Init end always @(posedge clk or posedge clk2) begin case (state_var) init: begin counter = 3'd0; state_var <= run; end run: begin if (counter == 2'd0) begin out<= 1'b1; end if (counter == 2'd1) //50% duty cycle begin out<= 1'b0; end if (counter == 2'd1) //Restart at 50% duty cycle begin counter <= 2'd0; end else begin counter <= counter + 1'b1; end end endcase end endmodule
Even of you do stimulate it, the problem will be synthesis. Registers in an fpga can only be clicked from a single clock. Also 300 mhz is about the limit of a cyclone.
What do you mean by the registers can only be clicked from a single clock? Are you referring to the always loop being entered or are you meaning the values within the registers can only be updated with one clock?
I thought that the always blocks would be entered when a new 'event' occurred. So when either clock has a rising edge, this would trigger the always block to run. I don't particularly see the difference between 2 clock inputs and 2 other inputs where the data is flowing in just as fast. I do know that verilog describes hardware - some times i just find it easier to talk about it as if it was software.
I backed off the PLL so they outputted 20Mhz each, which 40Mhz is no where near the Max frequency. I still didn't get anything out of it. I thought this would have worked. How do people manage to obtain DDR operation?
In verilog, you are right, the always block will always be entered when you get an event on clk or clk2:
So it's perfectly legal Verilog. The problem is it will not map to anything on an FPGA, as they can only accept a single clock per register. Your code has to be translated to real hardware, so you need to bare this in mind.
I suggest you output a 40MHz clock from your PLL
