21602 Discussions
With the Cyclone V SoC, how can I use the FPGA fabric to access the HPS DMA?
Hello everyone,
I want to make something that records values that are in my FPGA. I thought of using the Cyclone V SoC DMA, I do have the Altera SoC kit.
With the Cyclone V SoC, how can I use the FPGA fabric to access the HPS DMA? I want to set a trigger in the HPS DMA, so that when I send a signal to high level at FPGA Fabric, the DMA starts to copy a FPGA FABRIC RAM content to the DDR connected in the HPS and visible by the Linux running in the ARM.
*Is this the easiest/fastest way of achieving what I want?
Hi Dear aprado,
Could you please share your design to give me a guide? I'm blocked on FPGA-to-SDRAM + DMA for days.
My email is : yuchen.he@fime.com
Thank you very much for your help!
Kind regards,
Yuchen
If you are trying to move data between the HPS and FPGA have a look at this design, in the documentation directory you can review bandwidth numbers to see which path makes sense for your system: https://www.altera.com/support/support-resources/design-examples/soc/fpga-to-hps-bridges-design-example.html
As a general rule of thumb if you need to perform cacheable accesses use the F2H bridge with a DMA implemented in the FPGA, if you don't require cacheable accesses use the F2S ports and a FPGA DMA since that's where the bulk of the bandwidth is.
