Programmable Devices
21615 Discussions
Writing and Reading Data To & From RAM
I am trying to create a RAM (which is of 32*4 size) using the Mega Wizard Plug In Manager. So there are 32 rows into which data of 4 bits long can be written. The initialisation of the RAM is successful. Now, in order to fill the data into the RAM's locations one after the other, I have created an FSM which has a counter running from 0 to 31. The counter value is the address of the RAM. Thereby data is written onto the locations of the RAM.
When i simulate this program on the software, I get proper results. But when I try to run this program on the FPGA, I need to change the input and output variables such as data, input and output to SW[3:0], LEDG, LEDR etc. After changing like this, I am getting errors on the Software. When I try to mend the errors and run the program on FPGA the output does not come correctly on the FPGA. So I try to write a single bit into each location into the RAM but in vain again. I have tried all kinds of tweaking but FPGA still does not recognise the RAM. The code for the program is:
module ram (SW,LEDG,LEDR,clock);
input clock;
input [9:0] SW;
output [9:0] LEDR;
output [7:0] LEDG;
`ifndef ALTERA_RESERVED_QIS
// synopsys translate_off
`endif
reg GrOp;
integer wraddress;
integer rdaddress;
wire FSMW, wre;
assign FSMW = SW[7];
assign wre = FSMW ;
reg Ready1;
reg [3:0] out;
initial
begin
out = 4'b0000;
rdaddress = 4'b0000;
wraddress = 4'b0000;
end
always @ (posedge clock)
begin
Ready1 = 1'b0;
wraddress <= out; // wraddress <= out;
rdaddress <= out;
Ready1 = 1'b1;
out = out + 1;
GrOp = Ready1;
end
assign LEDG = GrOp;
// synopsys translate_on
`endif
wire [3:0] sub_wire0;
wire [9:0] LEDR = sub_wire0/*[3:0]*/;
altsyncram altsyncram_component (
.wren_a (wre), // SW[5]
.clock0 (clock),
.address_a (wraddress),
.address_b (rdaddress),
.data_a (SW), //.data_a ([3:0] SW),
.q_b (sub_wire0),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clock1 (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.data_b ({4{1'b1}}),
.eccstatus (),
.q_a (),
.rden_a (1'b1),
.rden_b (1'b1),
.wren_b (1'b0));
defparam
altsyncram_component.address_reg_b = "CLOCK0",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_a = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
altsyncram_component.intended_device_family = "Cyclone II",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 16,
altsyncram_component.numwords_b = 16,
altsyncram_component.operation_mode = "DUAL_PORT",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_b = "UNREGISTERED",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE",
altsyncram_component.widthad_a = 4,
altsyncram_component.widthad_b = 4,
altsyncram_component.width_a = 4,
altsyncram_component.width_b = 4,
altsyncram_component.width_byteena_a = 1;
endmodule
Please let me know how to overcome this problem in Altera FPGA.
you really want to enable the read_enable on both sides all the time? You can use the signaltap to see how your signals handling the RAM. I think this can help you to see where the problem is.
Thanks for the reply, JacoL. I checked the RTL schematic of the code on Quartus. rden_a & rden_b pins are both at logical 1 by default. The Quartus software I use does not have a signaltap feature.
I have some other programs (for eg adder) on FPGA...they have all worked fine. Only this RAM program doesn't work. The FPGA does not recognise the format of the program somehow.
