I am trying to create a RAM (which is of 32*4 size) using the Mega Wizard Plug In Manager. So there are 32 rows into which data of 4 bits long can be written. The initialisation of the RAM is successful. Now, in order to fill the data into the RAM's locations one after the other, I have created an FSM which has a counter running from 0 to 31. The counter value is the address of the RAM. Thereby data is written onto the locations of the RAM. When i simulate this program on the software, I get proper results. But when I try to run this program on the FPGA, I need to change the input and output variables such as data, input and output to SW[3:0], LEDG, LEDR etc. After changing like this, I am getting errors on the Software. When I try to mend the errors and run the program on FPGA the output does not come correctly on the FPGA. So I try to write a single bit into each location into the RAM but in vain again. I have tried all kinds of tweaking but FPGA still does not recognise the RAM. The code for the program is: module ram (SW,LEDG,LEDR,clock); input clock; input [9:0] SW; output [9:0] LEDR; output [7:0] LEDG; `ifndef ALTERA_RESERVED_QIS // synopsys translate_off `endif reg GrOp; integer wraddress; integer rdaddress; wire FSMW, wre; assign FSMW = SW[7]; assign wre = FSMW ; reg Ready1; reg [3:0] out; initial begin out = 4'b0000; rdaddress = 4'b0000; wraddress = 4'b0000; end always @ (posedge clock) begin Ready1 = 1'b0; wraddress <= out; // wraddress <= out; rdaddress <= out; Ready1 = 1'b1; out = out + 1; GrOp = Ready1; end assign LEDG = GrOp; `ifndef ALTERA_RESERVED_QIS // synopsys translate_on `endif wire [3:0] sub_wire0; wire [9:0] LEDR = sub_wire0/*[3:0]*/; altsyncram altsyncram_component ( .wren_a (wre), // SW[5] .clock0 (clock), .address_a (wraddress), .address_b (rdaddress), .data_a (SW), //.data_a ([3:0] SW), .q_b (sub_wire0), .aclr0 (1'b0), .aclr1 (1'b0), .addressstall_a (1'b0), .addressstall_b (1'b0), .byteena_a (1'b1), .byteena_b (1'b1), .clock1 (1'b1), .clocken0 (1'b1), .clocken1 (1'b1), .clocken2 (1'b1), .clocken3 (1'b1), .data_b ({4{1'b1}}), .eccstatus (), .q_a (), .rden_a (1'b1), .rden_b (1'b1), .wren_b (1'b0)); defparam altsyncram_component.address_reg_b = "CLOCK0", altsyncram_component.clock_enable_input_a = "BYPASS", altsyncram_component.clock_enable_input_b = "BYPASS", altsyncram_component.clock_enable_output_a = "BYPASS", altsyncram_component.clock_enable_output_b = "BYPASS", altsyncram_component.intended_device_family = "Cyclone II", altsyncram_component.lpm_type = "altsyncram", altsyncram_component.numwords_a = 16, altsyncram_component.numwords_b = 16, altsyncram_component.operation_mode = "DUAL_PORT", altsyncram_component.outdata_aclr_b = "NONE", altsyncram_component.outdata_reg_b = "UNREGISTERED", altsyncram_component.power_up_uninitialized = "FALSE", altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE", altsyncram_component.widthad_a = 4, altsyncram_component.widthad_b = 4, altsyncram_component.width_a = 4, altsyncram_component.width_b = 4, altsyncram_component.width_byteena_a = 1; endmodule Please let me know how to overcome this problem in Altera FPGA.Link Copied
you really want to enable the read_enable on both sides all the time? You can use the signaltap to see how your signals handling the RAM. I think this can help you to see where the problem is.- Mark as New
Thanks for the reply, JacoL. I checked the RTL schematic of the code on Quartus. rden_a & rden_b pins are both at logical 1 by default. The Quartus software I use does not have a signaltap feature.
I have some other programs (for eg adder) on FPGA...they have all worked fine. Only this RAM program doesn't work. The FPGA does not recognise the format of the program somehow.
