21611 Discussions
Xilinx fddrrse primitive
Is there an Altera primitive to create an FDDRRSE?
sync_clk_ddr : fddrrse port map (
Q => dds_sync_clk,
C0 => clk_125,
C1 => clk_125_inv,
CE => '1',
D0 => '1',
D1 => '0',
R => '0',
S => '0');
--- Quote Start ---
--- Quote End ---
Probably. But providing a port map tells us absolutely nothing.
Explain what you are using the component for.
Cheers,
Dave
TO_BE_DONE
--- Quote Start ---
Sorry, but I figured it out... I'm using the altddio_in MegaFunction.
--- Quote End ---
That was the component I was going to recommend :)
If your external signals are LVDS, then there are also altlvds_rx/tx components.
Cheers,
Dave
I do have one question about the altddio_out/altddio_in. I'm creating the altddio_out with a bit width of 1. The wizard generates a variation file with the following entity...
ENTITY sync_clk_ddr IS
PORT
datain_h : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
datain_l : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
outclock : IN STD_LOGIC ;
dataout : OUT STD_LOGIC_VECTOR (0 DOWNTO 0)
END sync_clk_ddr;
When I go to use this MegaFunction, it expects the data_in and data_out to be a vector. I'm trying to assign the data_out to a std_logic. Is there a way to convert froma std_logic_vector to std_logic?
--- Quote Start ---
--- Quote End ---
Yeah, use
dataout(0) <= dataout
where the signal dataout is std_logic.
Cheers,
Dave
