21615 Discussions
Yocto for Cyclone V
current Yocto release for Altera Cyclone V is the Danny release.
When will there be a Dylan release?
Kirby
Anyone have any idea?
Good news.
I have found an unofficial link.
I have got it bitbaking already.
I found an unofficial release of dylan:
http://git.rocketboards.org/?p=poky-socfpga.git;a=shortlog;h=refs/heads/dylan-altera
Unpack it into a new directory and then follow the bitbake procedure as follows:
http://www.rocketboards.org/foswiki/documentation/alterasocdevelopmentboardyoctogettingstarted
Kirby
my post with URLs has not shown up yet, so look on rockboards org site under git dylan-altera and get the snapshot.
Kirby
hi kirby, could you be more precise where we can find the snapshots?
You can find the snapshots at:
http://git.rocketboards.org/poky-socfpga.git/ (http://git.rocketboards.org/poky-socfpga.git/
Look for the build you want and click on the snapshot link and it will prompt you to download a .tar.gz
Then uncompress them into the directory you want to and then follow the bitbake procedure:
hob is still having issues.
Kirby
Hi all,
Did anybody get perf tool to build? it fails to find libelf.h.. What am I doing wrong?
Thanks for your quick response<85> Below the steps I have been using.
Look forward to your help on this issue..
Suresh
$ cd ~
$ git clone http://git.rocketboards.org/poky-socfpga.git
$ cd poky-socfpga/
$ git checkout -b <test_branch> ACDS14.0_REL_GSRD_PR
$ source ./altera-init build
$ bitbake perf
Note: replace <test_branch> with the name of the branch you want to use locally.
This fails with
[snagarajan@moltar-76 perf]$ alias armmake='make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm'
[snagarajan@moltar-76 perf]$ PATH=~/gcc-linaro-arm-linux-gnueabihf-4.9-2014.07_linux/bin:$PATH
[snagarajan@moltar-76 perf]$ armmake install
BUILD: Doing 'make -j4' parallel build
Auto-detecting system features:
... backtrace: [ on ]
... dwarf: [ on ]
... fortify-source: [ on ]
... glibc: [ on ]
... gtk2: [ OFF ]
... gtk2-infobar: [ OFF ]
... libaudit: [ on ]
... libbfd: [ on ]
... libelf: [ on ]
... libelf-getphdrnum: [ on ]
... libelf-mmap: [ on ]
... libnuma: [ OFF ]
... libperl: [ on ]
... libpython: [ on ]
... libpython-version: [ on ]
... libslang: [ OFF ]
... libunwind: [ OFF ]
... on-exit: [ on ]
... stackprotector: [ on ]
... stackprotector-all: [ on ]
... timerfd: [ on ]
config/Makefile:329: No libunwind found, disabling post unwind support. Please install libunwind-dev[el] >= 1.1
config/Makefile:368: slang not found, disables TUI support. Please install slang-devel or libslang-dev
config/Makefile:381: GTK2 not found, disables GTK2 support. Please install gtk2-devel or libgtk2.0-dev
config/Makefile:536: No numa.h found, disables 'perf bench numa mem' benchmark, please install numa-libs-devel or libnuma-dev
FLEX util/pmu-flex.c
CC util/environment.o
CC util/event.o
CC util/evlist.o
In file included from util/callchain.h:8:0,
from util/hist.h:6,
from util/evsel.h:11,
from util/evlist.h:8,
from util/evlist.c:15:
util/symbol.h:17:20: fatal error: libelf.h: No such file or directory
# include <libelf.h>
compilation terminated.
make[1]: *** [util/evlist.o] Error 1
make[1]: *** Waiting for unfinished jobs....
