21611 Discussions
a problem about ad ip core
Hello everybody,
I run into a problem about ad ip core for TLC549 which is made by myself.When I only debug .vhd files,the result is right,the output is 8-bit A/D value;while I use niosii and software ,the result is not correct.It's always a constant value 570mv which is shown in console of niosii.I have checked .vhd and .c.h files for many times but still don't kown why.So I need the help of my friends.The attachment included are my ad ip core source files.Expect your reply.Thank you very much!
junjun98
The problem has been solved by myself,thank you all the same.
