about if
hello,
do you know how to terminate an "if" instruction? the instructions are repeating over and over again and i don't want to repeat.I need a break terminal or something like that.I search on the net but it doesn't work.If you know...please help.
Best regards, tastax
if in C on a Nios ?
if in VHDL ?
if in Verilog ?
Is the "if" in HDL and is it inside a clocked process/always block ?
is in verilog and is in a clocked always block. How can i execute the if instruction just once?
It will be executed every time the clock comes.
The only way to avoid it is to remember that it was already ran once:
logic once = 1'b0;
always @ (posedge clk) begin
if (once == 1'b0) begin
// insert your code here
once <= 1'b1; // remember that it already ran once
end
end
thx a lot! your example was very helpfull for me and it works for my project!
