21611 Discussions
add_sw_property now all-caps unquoted strings (v11.0)
We had device drivers and rtos package described using _sw.tcl scripts.
Some of those are using the following Tcl command to generate defines in the auto-generated system.h file, like this:
add_sw_setting unquoted_string system_h_define timer.config_cpu_clk_hz MY_CONFIG_CPU_CLK_HZ "((unsigned long) PORT_SYS_CLK_FREQ)" "Frequency of the core processor"
This was working fine until we switched from v8.1 to v11.0. Now the resulting defines are all caps like:
# define ((unsigned long) PORT_SYS_CLK_FREQ)
...which obviously generates a compiler error. So now it is forbidden to use any std C identifiers for type, qualifiers, custom types or whatever that have small caps in it.
Altera says it depends on the Java lib they use and won't fix it. I highly doubt this.
Any work around?
