21602 Discussions
alt_timestamp timer information
I am using the interval timer for my design. Below is part of C code I used. The elapsed time I am getting is around 1000 ticks. I have this doubt that this part of code will take 1000 cycles to run or am I doing something wrong? Also, I would like to know what is the difference between performance counter and interval timer when it comes measuring the time elapsed?
if ( alt_timestamp_start() < 0 )
printf("No timer devices available.\n\n");
time_elapsed = alt_timestamp();
printf("Time elapsed %ld\n\n", time_elapsed);
hi.,
i am implementing dual NIOS-II system on DE2 board.
i could not solve the following error::
"timestamp value does not match : image on board is older than expected"
read timestamp 5:29:59 1970/01/01; expected 1:15:38 2014/05/06
the software you are downlaoding may not run on the system which is currently configured into the device.plaese download the correct SOF or recompile.
restarting the target processor.
regards...
