21615 Discussions
altclkctrl and state machine outputs
I am trying to drive the clkselect signal from the output of a statemachine
called adc_clksel however the compiler thinks that adc_clksel is a constant signal and I'm not sure why ??? Heres the Error and I am able to control the clk select block driven by another signal. I am using QII v9.0 and my device is Cyclone III
Error: inclk[1] port of Clock Control Block "TDR_FSM:TDR_FSM_1|tv220_clk_mux:ADC_clk_sel_inst|tv220_clk_mux_altclkctrl_9nd:tv220_clk_mux_altclkctrl_9nd_component|clkctrl1" cannot be used when clkselect port is not used or is a constant
Heres an overview of what Im doing I have edited the statemachine for brevity
signal adc_clkselect, clksel : std_logic;
ADC_clk_sel_inst : tv220_clk_mux PORT MAP (
clkselect => adc_clksel,
inclk0x => adc_clk(0),
inclk1x => adc_clk(1),
outclk => HS_ADC_clk
process( CNTRL_STATE, AE_PhaseDone, trigger, ControlReg(14) )
begin
case CNTRL_STATE IS
when IDLE =>
adc_clksel <= '0' ;
if trigger = '0' then
NX_CNTRL_STATE <= IDLE ;
else
NX_CNTRL_STATE <= ZERO_PHASE ;
end if;
when ZERO_PHASE => -- Acquire data from A2D
counter_select <= b"100" ;
adc_clksel <= '0' ;
AEng_start <= '0';
if AE_PhaseDone = '1' then -- DONE
NX_CNTRL_STATE <= ONE_EIGHTY_PHASE ;
else
end if;
when ONE_EIGHTY_PHASE =>
counter_select <= b"101" ;
adc_clksel <= '1' ;
else
NX_CNTRL_STATE <= ONE_EIGHTY_PHASE;
end if;
when OTHERS =>
NX_CNTRL_STATE <= IDLE ; -- Full trace complete
end case;
end process;
