21599 Discussions
[altera_mf] how to pre-compile?
Hi All,
How is it possible to pre-compile the altera_mf lib? I need it for an external tool.
Thank you!
--- Quote Start ---
Hi All,
Thank you!
--- Quote End ---
Precompile it into what?
Precompiler into a library...
1) I want to simulate Altera IP in Quartus using QuestaSim
Here are the lines inside of one of the VHDL file:
LIBRARY altera_mf; USE altera_mf.all;
So, I need to know how to compile the altera_mf lib...
2) I'm using Sigasi. They also need the altera_mf lib pre-compiled...
In Quartus II, you can launch the EDA Simulation Library Compiler using: Tools-> Launch Simulation Library Compiler.
Then you have to set the paths to the libraries in the modelsim.ini file for QuestaSim.
