21602 Discussions
altera_reset_synchronizer_int_chain_out
Hi all
i builted a large design for Startix IV 530.
i'm using up to 630 DSP blocks in my design.
if let it run (compile) normaly, i get "altera_reset_synchronizer_int_chain_out" timming falling paths.
if i add set_false_path command to my project SDC file, i get an error about the amount of DSP blocks
"can not find legal placement for <x> dsp blocks".
how can i solve this issue?
inon_y
how are you setting the false path?
--- Quote Start ---
--- Quote End ---
set_false_path \-from {..|altera_reset_synchronizer_int_chain_out} \-to [all_registers]
That's not good, your just sweeping issues under the "false path" rug.
You should set a false path between the reset input signal and the synchronization registers _IF_ the reset signal is asynchronous in respect to the target clock.
If you still get failing paths after that, then you have a problem that affects timing and you need to take care of it that way.
Maybe the reset output needs to be driven to a global clock signal and Quartus is failing to do so automatically?
