21611 Discussions
altsyncram file for Modelsim Simulation
GD76
In Platform Designer, I have dual port RAM. In Modelsim, I have the verilog Block RAM file. That file calls altsyncram. In simulation, I have test bench and the verilog block RAM file. Where do I find the altsyncram file. In my search, I cannot find that file to include in DO file to compile.
ShengN_Intel
Hi GD76,
FYI,
Altsyncram module is in modelsim_ase/altera/verilog/altera_mf file.
Using vsim -L altera_mf_ver during simulation will do.
This command executes searching of altsyncram module in altera_mf library.
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
ShengN_Intel
Hi GD76,
Do you have any further update on this thread?
Sheng
ShengN_Intel
Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
Sheng
