21584 Discussions
arria 10 lvds serdes
LLCC
hello,
I was originally using the quartus 17.1 Standard Edition to complete some designs that include LVDS SERDES IPs, and the projects were able to pass compilation successfully. However, when I migrated these projects to 22.1 Pro, compilation errors occurred, even though I am certain that the designs are identical to the original versions.
Here are one of the details of the error messages encountered:
Error(129015): Output port RXDATA on atom "data_rx_top_u0|one_rx_module_u3|lvds_rx_u0|chan17_u0|lvds_0|core|arch_inst|channels[9].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive, is not legally connected and/or configured
Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected
Info(11951): Module instance "data_rx_top_u0|one_rx_module_u3|lvds_rx_u0|chan17_u0|lvds_0|core|arch_inst|channels[9].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 6 connected to TXDATA port.
"I am very sure that the code is correct, and it compiled and passed simulation successfully in the 17.1 Standard Edition. Why am I encountering compilation errors in 22.1 Pro?"
LLCC
hello,How can I send my project to you privately? Please help me review it to see where the errors are. I really can't find the problem. Thank you.
HortumNecmi
Hello, I am having a similar problem, did you solve the problem?
AqidAyman_Intel
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
AqidAyman_Intel
Can you try to regenerate the Altera LVDS SERDES Receiver IP?
Or else, you can try to connect them up in your design.
LLCC
Thank you. I have already solved this problem. My feeling is that when the data output by this IP is being processed logically, it requires data from all channels to be used together. For example, if I only use the output data from a single channel to complete a certain logical process, while the output data from other channels is used for another logical process, it may trigger the aforementioned error.
HortumNecmi
Thanks for the answer, I connected all bits (used and unused) to a logical operator (or) and assigned the output to one pin. And the problem was solved.
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
anonimcs
New Contributor III
Hi @HortumNecmi @LLCC ,
I'm facing the same issue, but I already have the bits connected to an input port on one end and to an intermediate pin on the other end. I have this piece of code on my toplevel HDL and I'm not sure what is still missing.
-- group the block/polarization data together for the serdes IPs
    adc_if_0x_rx_in <= T1_X_FCLK & T1_R8X_I & T1_R8X_Q &
                       T1_X_FCLK & T1_R7X_I & T1_R7X_Q &
                       T1_X_FCLK & T1_R6X_I & T1_R6X_Q &
                       T1_X_FCLK & T1_R5X_I & T1_R5X_Q &
                       T1_X_FCLK & T1_R4X_I & T1_R4X_Q &
                       T1_X_FCLK & T1_R3X_I & T1_R3X_Q &
                       T1_X_FCLK & T1_R2X_I & T1_R2X_Q &
                       T1_X_FCLK & T1_R1X_I & T1_R1X_Q;
-- some code in between
-- LVDS SERDES
    adc_if_0x : component lvds_tile
    port map (
        inclock             => FPGA_REFCLK_ADC, -- adc_sample_clk 50 MHz
        pll_areset          => core_reset,
        pll_locked          => adc_if_0x_pll_locked,
        rx_in               => adc_if_0x_rx_in,
        rx_out              => adc_if_0x_data_out,
        rx_coreclock        => adc_if_0x_rx_coreclock, -- 50 MHz (SERDES Factor 7)
        rx_dpa_reset        => adc_if_0x_rx_dpa_reset,
        rx_dpa_locked       => adc_if_0x_rx_dpa_locked,
        rx_bitslip_ctrl     => adc_if_0x_rx_bitslip_ctrl,
        rx_bitslip_reset    => adc_if_0x_rx_bitslip_rst
The lvds_tile component was defined and added to the project. I'm not getting any syntax error. I'm using a 24 channel approach (see the concatenation at line 2) with a serialization factor of 7. But I'm getting errors like the error given below (I get it for all 24 bits of channel[]) when I try to compile on Quartus Pro 21.3. I've verified that the Platform Designer connects 'adc_if_0x_data_out' to an intermediate block as well, so it's not optimized away either.
I'd be appreciated if you could give me a hand here.
Cheers
Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[23].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured
Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected
Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[0].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port.
FvM
the error message sounds like your intermediate block doesn't provide an actual connection for SERDES rx_out. Can you try to export at least some channels to top level pins for test?
anonimcs
New Contributor III
I have done it, and it seems like the errors I got are related to the connection of 'rx_dpa_locked'. But feels odd because the compiler complains about the rx_out's connection whereas the errors are gone when I make the dpa_locked connection of the exported qsys component open.
