21613 Discussions
associate signal tap .stp file with a megawizard generated signal tapproject
I add a signal tap component generated with megawizard in my project.
I have connected signals on its input : clock, data and trigger signals.
Is it possible to create an instance in signaltap II analyzer which integrate automatically megawizard parameters ?
When I create an instance manually, I can't run signal tap. The sof manager says that my instance is not compatible with the sof file.
I use this method :
- set the same clock, sample depth, continuous storage
- add signals (data and trigger) connected to the signal tap component (using "signaltap II: pre-synthesis" filter)
What is the correct method to use signal tap from a megawizard file and create a valid .stp file?
I found the solution, the menu was in quartus, not in signal tap analyzer.
So the correct way is:
quartusII / file / creat-update / create signal tap II file from design instance
Thanks. That's exactly what I need.
--- Quote Start ---
--- Quote End ---
