21611 Discussions
basic example Avalon MM bus
Hi guys!!!
I'd like to learn to use a avalon mm bus in my Cycone II using qsys, but I dont have a good tutorial where I can learn it .
Could you give a good example or reference where can I learn to use it?
PD: my FPGA doesn't has a NIOS
I want to implement Qsys without NIOS.
I've attached image where I made a system. I've conected a GIPO (avalon MM slave) with Avalon MM master translator.
My idea is using a Avalon MM master translator to send datas to GPIO (avalon MM slave) (I think that system is basic to start :confused:)
I've got some questions:
My system works?.... If works... How should I setup Avalon MM master translator and GPIO?
I've notice through forum and internet that Qsys must be implemet to one NIOS application (Am I right?), because I've couldn't to find a project or tutorial that showing me the opposite.
No, Nios is not required to control things. You could create a state machine as a custom master component. There are lots of free online trainings to get started with Qsys:
https://www.altera.com/support/training/catalog.html?coursetype=online&language=english&keywords=qsys
