21611 Discussions
changing floating license port speeds compile
Why would changing the floating license port from 1819 to 1820 speed up Quartus compileing times?
you could try lmutil lmstat -a -c port@server with the bad port and good port and see if the server has a bit of latency on the bad port
Here is the result of that;
C:\Windows\system32>lmutil lmstat -a -c 1819[at]ourlicenseserver.cornell.edu lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corp
oration. All Rights Reserved.
Flexible License Manager status on Wed 10/19/2011 10:11
[Detecting lmgrd processes...]
License server status: 1819[at]EN-LICSRV
License file(s) on EN-LICSRV: 1819[at]ourlicenseserver.cornell.edu
lmgrd is not running: License server machine is down or not responding. (-96,7:1
1001 "WinSock: Host not found (HOST_NOT_FOUND)")
Any ideas?
The problem comes when students change this port (see below), then ModelSim does not work;
Prof.,
After some digging around, it seems that editing the license file prevents quartus from long delays before it will compile. (Perhaps it tries to ping the wrong server at first?)
I opened up
c:\altera\license.dat
in a text editor and changed the last number on the first line from 1819 to 1820
The file now reads:
SERVER licsrv.engineering.cornell.edu 00505694574A 1820
USE_SERVER
This seems to have shaved a full minute off the compile time (a factor of 2 speedup for the last project)
Choon Lee,
We found the answer. Change the license.dat on the client computer to point to port 1820 (for Quartus compile speedup) . Then, change the ENV variable on the client computer to point to port 1819 (for ModelSim license). Compile speeds are down to ~30 seconds, and ModelSim can find it's license. All works fine now.
Thank you,
Doug
License.dat file;
SERVER [license.server.name] [MAC address of license svr] 1820
USE_SERVER
MGLS_LICENSE_FILE;
1819[at-sign][license.server.name]
