21618 Discussions
checks for synthesis rules
Hi all
I just want to know that apart from DRC checks is there anyother rule checking tool that i can use in synthesis.
I know about design assistant reliability check having 33 set of rules, so is there anyother such check having a rule set?
Are you looking for a more in depth lint checker? If so you might have to do so through whatever simulation tool you use. I know that ActiveHDL has a good linter. I'm not sure if modelsim supports linting.
/Boris
ohhh ok thanks lethenstrom ..
