21591 Discussions
compilation Error (10818): Can't infer register ...
hi all,
im trying to build a stopper using vhdl, modelsim and quartus.
i wrote the vhdl code and tried it on modelsim and everything was just fine, the compilation and sim were good, as i expected.
when i tried to compile it on quartus it gave me errors. im trying to understand how to fix it for more than 5 hours. please help me.
the errors are:
Code:
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 7.1 Build 178 06/25/2007 Service Pack 1 SJ Web Edition
Info: Processing started: Sun Dec 23 22:11:21 2012
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off stopper_new -c stopper_new
Info: Found 2 design units, including 1 entities, in source file stopper.vhd
Info: Found design unit 1: STOPPER-arc_stopper
Info: Found entity 1: STOPPER
Info: Found 1 design units, including 1 entities, in source file timer.bdf
Info: Found entity 1: timer
Info: Elaborating entity "timer" for the top level hierarchy
Warning: Using design file hexss.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project
Info: Found design unit 1: hexss-arc_hexss
Info: Found entity 1: hexss
Info: Elaborating entity "hexss" for hierarchy "hexss:inst2"
Info: Elaborating entity "STOPPER" for hierarchy "STOPPER:inst"
Warning (10492): VHDL Process Statement warning at stopper.vhd(70): signal "cnt_sec" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Warning (10492): VHDL Process Statement warning at stopper.vhd(71): signal "cnt_sec" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Warning (10492): VHDL Process Statement warning at stopper.vhd(72): signal "sec" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Warning (10492): VHDL Process Statement warning at stopper.vhd(73): signal "sec" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Warning (10492): VHDL Process Statement warning at stopper.vhd(74): signal "min" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Warning (10492): VHDL Process Statement warning at stopper.vhd(75): signal "min" is read inside the Process Statement but isn't in the Process Statement's sensitivity list
Warning (10631): VHDL Process Statement warning at stopper.vhd(25): inferring latch(es) for signal or variable "flag", which holds its previous value in one or more paths through the process
Error (10818): Can't infer register for "min[0]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[0]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[1]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[1]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[2]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[2]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[3]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[3]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[4]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[4]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[5]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[5]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[6]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[6]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[7]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[7]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[8]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[8]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[9]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[9]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[10]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[10]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[11]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[11]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[12]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[12]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[13]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[13]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[14]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[14]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[15]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[15]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[16]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[16]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[17]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[17]" at stopper.vhd(25)
Error (10818): Can't infer register for "min[18]" at stopper.vhd(49) because it does not hold its value outside the clock edge
Info (10041): Inferred latch for "min[18]" at stopper.vhd(25)
Error: Can't elaborate user hierarchy "STOPPER:inst"
Error: Quartus II Analysis & Synthesis was unsuccessful. 20 errors, 8 warnings
Info: Allocated 199 megabytes of memory during processing
Error: Processing ended: Sun Dec 23 22:11:22 2012
Error: Elapsed time: 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 20 errors, 8 warnings
see attached for the code
im a novice with vhdl so i would appreciate any help. thanks
for synthesis style vhdl you need to adhere to clocked process template like the second one of yours. The first process assigns clock edge after lots of if/elsif which is not allowed by synthesis tools(otherwise not wrong). All signal assignments inside clocked process infer registers and you are allowed either to start with
if clock edge...
or with reset then elsif clock edge... nothing extra on top.
Additionally you can just use: wait until clock = '1'; without any ifs.
The problem is here
if resetN = '0' then cnt_sec <= 0; sec <= 0; min <= 0; flag := 1; elsif stopN = '0' then flag := 1; elsif startN = '0' then flag := 0; end if; if rising_edge(CLK) then
Must be changed to something like below to be synthesizable.
if resetN = '0' then cnt_sec <= 0; sec <= 0; min <= 0; flag := 1; elsif rising_edge(CLK) then
The start and stop action should be done in a synchronous way.
By the way, every "similar thread" below is talking about the same problem.
thank you,
how can i do the stopN and startN in a synchronous way?
signal flag; -- process (CLK, -- elsif rising_edge(CLK) then if stopN = '0' then flag <= 1; elsif startN = '0' then flag <= 0; end if;
thank you very much!
