21599 Discussions
connecting be_n_to_the_ext_ssram[3:0] to IDT71V416 SRAM
Hello all,
I created using SOPC builder a NIOS II based system that includes an SRAM compatible with IDT71V416 listed in SOPC builder, for the SRAM, I added an IDT71V416 from Memories and Memory Controllers-->SRAM folder
the top level of the the NIOS II based system includes a 4 bit wide signal called "be_n_to_the_ext_ssram", and I dont know where to connect this signal, or even what this signal does, there is a vague description of it in Quartus II handbook volume 4 chapter 9 example 3, but I found it unhelpful
the SRAM IDT71V416 itself does not seem to have any 4 bit wide signal
can you help me with this problem
thanks in advance
js
the datasheet for the SRAM is here
http://www.olimex.com/dev/pdf/71v416_ds_74666.pdf
the top level NIOS II based system instantiation is here
//Example instantiation for system 'NIOSII'
NIOSII NIOSII_inst
.address_to_the_ext_flash (address_to_the_ext_flash),
.address_to_the_ext_ssram (address_to_the_ext_ssram),
.be_n_to_the_ext_ssram (be_n_to_the_ext_ssram),
.clk_0 (clk_0),
.data_to_and_from_the_ext_flash (data_to_and_from_the_ext_flash),
.data_to_and_from_the_ext_ssram (data_to_and_from_the_ext_ssram),
.in_port_to_the_button_pio (in_port_to_the_button_pio),
.out_port_from_the_led_pio (out_port_from_the_led_pio),
.out_port_from_the_seven_seg_pio (out_port_from_the_seven_seg_pio),
.read_n_to_the_ext_flash (read_n_to_the_ext_flash),
.read_n_to_the_ext_ssram (read_n_to_the_ext_ssram),
.reset_n (reset_n),
.select_n_to_the_ext_flash (select_n_to_the_ext_flash),
.select_n_to_the_ext_ssram (select_n_to_the_ext_ssram),
.sys_clk (sys_clk),
.write_n_to_the_ext_flash (write_n_to_the_ext_flash),
.write_n_to_the_ext_ssram (write_n_to_the_ext_ssram)
further information about .be_n_to_the_ext_ssram is here
<edited>
output [ 3: 0] be_n_to_the_ext_ssram;
<edited>
be_n_to_the_ext_ssram signals is for BHE/BHL of the SRAM device. Since the sram controller in SOPC Builder has 32 bit data width and requires two IDT71V416 devices, it has four bit be_n. You can refer to Altera DSP kit schematic which utilizes IDT71V416:
http://www.altera.com/literature/ds/schem_p06_10217r_03_stratixii_dsp_board_sch_4_6_06.pdf
If you have one IDT71V416 on your board, you need a custom interface for the sram such as attached(custom_memory -> sram_256Kx16bit).
Thanks for your prompt response, I unzipped the file sram_256Kx16bit_hw.tcl
and tried to source it from Quartus II Version 9.0 Build 235 06/17/2009 SJ Web Edition
it produced error message
Error: invalid command name "set_module_property"
as a 2nd attempt, I launched SOPC builder from within Quartus II, and launched system console, then sourced the file. the same error message appeared
any help is greatly appreciated
thanks
js
The *_hw.tcl is not for system console. It’s a custom component definition file for SOPC Builder and SOPC Builder reads the file automatically in its start-up.- Copy the *_hw.tcl to your Quartus II project directory.
- Start Quartus II, open the project and launch SOPC Builder
- You will see a new component “custom_memory -> sram_256Kx16bit” in your component Library list.I made the _hw.tcl file:- from SOPC Builder menu: File -> New component…
- Add signals in Signals tab
- Define timing parameters in Interfaces tab
- Give names/group in Component Wizard tabIt’s not so complicated work. You can also modify the component parameters as you want by right-click -> Edit… , and I recommend it :) .
thanks
it appeared automatically in the component library before and I didn't notice it, after regenerating the system with the new 16 SRAM interface, now the signal be_n_to_the_ext_ssram is 2 bits wide, and corresponds to BH_n and BL_n in the IDT71V416
tommorrow I will download the design to the evaluation board
thanks
js
sorry duplicate
js
I generated an SOPC system using the custom 16 bit SRAM controller sram_256Kx16bit_hw.tcl
result:the SRAM address width was generated as 19 bits wide although the IDT71V416 (ISSI IS61WV25616BLL) has only 18 bits
as seen below from the NIOSII_system module definition of the address to the external SRAM
output [ 18: 0] address_to_the_ext_sram_256Kx16bit;
what is the best action to take to connect the 18 bit SRAM address lines
thanks
js
because it's 16 bit memory, you should omitted A0 of FPGA.
connect FPGA's A1 to SRAM's A0, A2 to A1, and so up.
Hi, i met this problem when i add in sram_256Kx16bit_hw.tcl in my project file, add place the new component into SOPC, pls advise.
Error: sram_256Kx16bit_0: set_module_property: INTERNAL not allowed for EModuleProperty, must be in {[DESCRIPTION, NAME, VERSION, MODULE_TCL_FILE, MODULE_DIRECTORY, GROUP, AUTHOR, ICON_PATH, DISPLAY_NAME, LIBRARIES, DATASHEET_URL, TOP_LEVEL_HDL_FILE, TOP_LEVEL_HDL_MODULE, INSTANTIATE_IN_SYSTEM_MODULE, EDITABLE, VALIDATION_CALLBACK, EDITOR_CALLBACK, GENERATION_CALLBACK, ELABORATION_CALLBACK]}
Error: .avalon_tristate_slave: setParameter: No parameter ENABLED
Error: .avalon_tristate_slave: getParameter: No parameter ENABLED
-Lavenderpuppy-
I added flash and sram 256x16. In sopc project I have 2 address spaces: one for flash and one for sram but I have one space for data: 16 bits. Sram have 16 bit data bus and flash 8 bits. have can I connect flash and sram to one 16 bits bus?
