21602 Discussions
connectivity warnings - see the Connectivity Checks report folder
Hi all,
I'm designing a biometric system in RTL using verilog. But I keep getting this warning during compilation.
warning: 2 hierarchies have connectivity warnings - see the connectivity checks report folder.
I wonder how to resolve this warning and where is that "connectivity checks report folder" located?
Thank in advance,
ty6
--- Quote Start ---
Hi all,
Thank in advance,
ty6
--- Quote End ---
you find the folder "Connectivity Checks" in the Compilation report under "Analysis & Synthesis"
Kind regards
GPK
Hi all,
The automatic display of the Compilation Report itself can be disabled in the settings of Quartus.
To activate the report you can use CTRL+R, then you can proceede as mentioned by GPK in the reply above.
To activate the compilation report manually: go to "Processing" [Top Menu]/ "Compilation Report"
Kind Regards,
Johi.
