21616 Discussions
custom phy rx_clkout no signal
Hi,all,I'm using the ArriaV GX FPGA Development Kit Board to test the custom phy.(software version:QII12.0,chip:5AGXFB3H4F40C5ES).I have successfully completed data transmission at duplex mode.And my application is:Source(TX) -> Sink(RX).So I Create a TX only and an RX only custom IP.But When I use the SignalTap to capture the receive data,the trigger clock is 'rx_clkout'.But the SignalTap status is "Waiting for clock".The pins of TX only/RX only are as same as the Duplex mode. I also simulate the project by modelsim,and find the rx_clkout is always high.
My configuration of the custom phy(RX only):
general:
Parameter validation rules: Custom
Mode of operation: RX
Number of lanes: 1
Enable lane bonding: off
FPGA fabric ransceiver interface widh: 16
PCS-PMA interface Width: 10
Ddata rate: 3125 Mbps
Input clock frequency: 125.0MHz
Create rx_coreclkin port: off
Create rx_recoverd_clk port: off
Create optional ports: off
Avalon data interfaces: off
Enabled embedded reset controller: on
pcs options:
Word alignment mode: Manual
Create optional word aligner status ports: off
Word aligner pattern length: 10
Word alignment pattern: 0101111100
Enable run length violation checking: off
Enable rate match FIFO: on
Rate match insertion/deletion +ve disparity pattern:10100010010101111100
Rate match insertion/deletion -ve disparity pattern: 10101011011010000011
Create optional Rate Match FIFO status ports:off
Enable 8B/10B encoder/decoder: on
Enable manual disparity control: off
Create optional 8B10B status ports: off
thank you!
Hi,I try to trun off the "Enable rate match FIFO",and the 'rx_clkout' signal present,Why can't trun on it? .My application like that,C2C(chip-to-chip) transmission between two chips,the source is TX only and sink is RX only.The chips have different local clock which in the different board.Without the Rate match FIFO,how can I ensure that the FIFO doesnot underflow or overflow due to per million(ppm) difference between the clocks?Waiting for your reply,thanks again.
